March 20, 2014, 15:17 |
Turbulent Flux Closure?
Kevin Hoopes
Rep Power: 16 |
I am doing a conjugate heat transfer model of flow in the back cavity of an centrifugal impeller. In the fluid models page of CFX-Pre there is an option: Turbulent Flux Closure. I have been reading in the help about it, but it does not give a recommendation on when to enable it. Does anything have any experience with this option to know what is advisable?
Thanks, Kevin |
March 20, 2014, 16:08 |
Rep Power: 143 |
The only thing I can see under that option is the Prandtl number - you don't want to adjust that, it is one of the key constants in the turbulence model. When the option is not selected then it uses the default Prandtl Number. To change it you activate the option. But to change it requires either bravery or naivety.
May 24, 2016, 23:21 |
Evan Oscar Smith
Rep Power: 14 |
If you select the option, but don't change the turbulent prandtl number, is that the same as not selecting it?
I just realised that one of my simulations had this option selected, but I didn't touch the default setting. Thanks, |
May 25, 2016, 00:43 |
Evan Oscar Smith
Rep Power: 14 |
My apologies, I just did some more reading and found this in the user guide:
When the heat transfer model is set to either Thermal Energy or Total Energy, the Turbulent Flux Closure for Heat Transfer may be optionally selected in the Turbulence settings. When Turbulent Flux Closure for Heat Transfer is not selected, the default is the Eddy Diffusivity model with the turbulent Prandtl number of 0.9. The turbulent Prandtl number may be non-constant using by expressions (CEL), for example, as a function of physical space or solution variables. For the two models where I accidentally selected it, the only option was eddy diffusivity (which is the default anyway from the looks of it) and as I mentioned, I left the turbulent Prandtl number set to 0.9. |
Description of flux() method | fumiya | OpenFOAM | 5 | January 2, 2018 11:05 |
Laminar vs Turbulent Navier-Stokes | truman | Main CFD Forum | 8 | July 10, 2017 07:20 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
turbulence flux closure for heat transfer | alinik | CFX | 3 | April 30, 2013 19:31 |
Heat Flux Profile at Fluid-Porous Interface | Hitch8 | CFX | 4 | December 15, 2012 09:57 |
