CFX4.3 Run as an Euler Code!!
Old   February 22, 2000, 12:37
Default CFX4.3 Run as an Euler Code!!
James Date
Hi, Can anyone tell me if it is possible to switch off the turbulence modelling in CFX4.3 and run it as an Euler Code. I know you can run it in Laminar mode, but is it possible to set the fluid viscosity to zero in the command file or through the user FORTRAN routines whereby the viscous terms are set to zero. Any answers much appreciated.
Regards
James
Old   March 3, 2000, 08:52
Default Re: CFX4.3 Run as an Euler Code!!
Andreas Abdon
I would try redefining your differencing scheme (excluding the diffusion terms) in user routine USRFDS.
Regards
Andreas
Old   March 6, 2000, 05:08
Jan Rusås
Hi James,
If you still need help on this topic, then you could look in the manual CFX-4.2 page 87, 5.19.3 Inviscid Euler equations. Set the flow to laminar and the molecular viscosity to a very small number (I have tried with 1.e-20, works fine) The boundary layer is switched off by setting WALL TREATMENTS to SLIP
Regards Jan
Old   March 6, 2000, 08:55
James Date
Many thanks Andreas & Jan for your help. I had a feeling that you needed to do something along the lines of what you have told me, but wasn't too sure.
Kind Regards
James Date
Error showed up when running code tangd OpenFOAM Running, Solving & CFD 1 July 14, 2006 04:26
Euler 2d code structured odianes Main CFD Forum 0 October 28, 2005 17:54
public CFD Code development Heinz Wilkening Main CFD Forum 38 March 5, 1999 11:44
I need free code of Multi-stage time stepping for Euler Equations Sam Main CFD Forum 0 January 2, 1999 03:25
What kind of Cmmercial CFD code you feel well? Lans Main CFD Forum 13 October 27, 1998 10:20
