error.cfx
Like Tree2Likes
  • 1 Post By ghorrocks
  • 1 Post By fahimeh456
Old   April 10, 2017, 14:15
Default error.cfx
bahar
fahimeh456 is on a distinguished road
Hi
every body can help me?
My model's mesh made within ICEM and then its physical set within CFX.
When I'm changing the number of nodes within ICEM then I'm faced with this error:
| ERROR #002100013 has occurred in subroutine Chk_Splane. |
| Message: |
| The symmetry boundary condition requires that the boundary patch |
| mesh faces form a plane or axis. However, face set 4 in the |
| symmetry boundary patch |
| symf |
| is not in a strict plane, which means that at least one of its |
| faces is not parallel to the others. To make the solver run |
| you can do one of the following: |
| (1) Make sure that this symmetry boundary patch is in a plane or |
| axis by checking and regenerating the mesh. |
| (2) If the symmetry boundary patch is an axis rather than a |
| plane, change the tolerance of the degeneracy check by |
| increasing the value of the Solver Expert Parameter |
| 'degeneracy check tolerance' (the default value is 1.e-4). |
| (3) Increase the value of the Solver Expert Parameter |
| 'vector parallel tolerance' (the default value is 1 deg.). |
| Note that the accuracy of the symmetry condition may decrease |
| as the tolerance is increased. This is because the tolerance |
| is the number of degrees that a mesh face normal is allowed |
| to deviate from the average normal for the entire face set. |
| An error has occurred in cfx5solve: |
| The ANSYS CFX solver exited with return code 1. No results file |
| has been created. |
please help me.
fahimeh456 is offline   Reply With Quote
Old   April 10, 2017, 18:21
Opaque will become famous soon enough
Open the definition file in CFD-Post, create a vector plot and plot the Normal variable on such mesh region/symmetry plane.
If the mesh is not planar, you have selected a mesh region for which a SYMMETRY boundary condition cannot be used. If the mesh is slightly non-planar, it is up to you to decide if you want to use the expert parameter to bypass the error message, and continue aware that something else may come out wrong later. Finally, the last recourse is to go back to the meshing program and find a way to create a true planar surface.
Hope the above helps,
Opaque is offline   Reply With Quote
Old   April 13, 2017, 03:24
bahar
This error created because I wanted to change my icem mesh size and I wanted to check independence in the mesh size.
While the initial mesh resolved without error.
Old   April 14, 2017, 11:53
bahar
grateful but,
I don't know,how I can create a vector plot and plot the Normal variable on such mesh region inside definition.
Old   April 15, 2017, 01:05
You can also do this in ICEM. Make the symmetry boundary the only thing visible and have a close look at it. You should see some elements which are off the intended plane. And the advantage of doing it in ICEM is that you can then fix the problem elements and eliminate the problem.
Old   April 17, 2017, 02:52
bahar
thank you so much
Old   April 19, 2017, 07:06
bahar
I want to change the value iteration of the cfx solver but I am faced with this error:
Old   April 19, 2017, 08:09
The error message tells you exactly what the problem is. If you put an integer in for the maximum number of iterations it will work. Isn't that obvious?
Old   April 19, 2017, 09:03
bahar
My problem solved with edit in command editor.thanks.
Old   April 20, 2017, 00:57
Tingyun YIN
Tingyun YIN is on a distinguished road
Hello fahimeh456
Did you solve your symmetry problem?
Now, I have the same problem: CFX can run 6 million nodes (first lawyer setting: 0.1) successfully, while when I increased the nodes up to 10 million nodes in ICEM (also I changed the first lawyer setting: 0.01), It failed to solve and symmetry error occurred. By the way, the 2*2*2 quality is 0.9 and angle is more than 36 for 10 million.
I tried to convert to the unstructured mesh by selecting "no projection" in ICEM. CFX ran a few step and stopped with error "overflow".
I didn't change the expert parameters suggested by CFX help. Because I believe it will result in a bad result.
My model is the Twisted-11 foil.
Many thanks!
Sent from my iPhone using CFD Online Forum mobile app
Tingyun YIN is offline   Reply With Quote
Old   April 20, 2017, 03:12
The non-planar symmetry plane error is a very simple one. Your symmetry plane is not planar. So load your mesh in ICEM and look carefully at the symmetry plane and find what is not planar. ICEM sometimes mis-classifies element faces resulting in this error, so you manual correct the part the elements are in and the error is fixed.
Tingyun YIN likes this.
Old   April 20, 2017, 03:16
bahar
hello,my friend
My problem solved when I raised the value of vector parallel tolerance in CFX's solver settings.
Because when the mesh is finer then elements angles change.
so the elements on the screen or edges are not connected.
Old   April 20, 2017, 03:42
Tingyun YIN
Okay, I see.
Thanks a lot
Old   April 20, 2017, 03:47
Tingyun YIN
Originally Posted by fahimeh456 View Post
hello,my friend
Yeah, I see. Another questions: Will increasing the tolerance lead to a bad result? So, any suggestions for setting the value of vector parallel tolerance?
Old   April 20, 2017, 07:27
bahar
I'm not sure,But when I tried it then I got a good answer.You can test different tolerance and select
the least amount of tolerance.
Old   April 20, 2017, 21:23
Tingyun YIN
I'm not sure,But when I tried it then I got a good answer.You can test Different tolerance and select
Hello, my friend
Follow your suggestions, I increased tolerance up to 5 and the result seemed good.
Many thanks!
Old   April 21, 2017, 04:22
Tingyun YIN
Increasing tolerance seems to be a good method, the calculation run successfully.
Many thanks.
