VVISCOUS HEATING CFX4.3
Old   October 5, 2001, 08:14
Default VVISCOUS HEATING CFX4.3
Fabian
Hi, when I use the "VISCOUS HEATING" option in a laminar pipe flow in CFX4.3 the cup mixing temperature of the fluid is higher at the inlet than at the outlet! Shouldn't the term be called "VISCIOUS COOLING" instead? For more information: I use a mass flow boundary at the inlet and at the outlet in order to get a fully developed flow, I have 41 cells in axial direction between inlet and outlet. I solved the viscious heating problem myself by adding heat sources via user-fortran. I am just curious if somebody else has noticed this bug.
Induction heating of hollow cylinder cfd.geek FLUENT 1 August 12, 2022 16:38
Pressure variation in a heating channel gRomK13 Main CFD Forum 0 August 6, 2009 12:18
Lower heating value Andrea Siemens 2 July 30, 2007 07:19
heat transfer - heating element to air in FloWorks Duncan Gravill Main CFD Forum 1 March 28, 2007 20:16
buoyancy driven flow in steady state in CFX4.3 raymondyin CFX 11 May 7, 2001 06:15
