Source term in energy equation
Old   June 7, 2006, 08:50
Default Source term in energy equation
macdidi
Hello I'm modelling heat transfer between fluid domain and solid. I've to add a souce term in energy equation of solid, This term depend on temperature, time and other variable. I do it using fortran subroutine. But I've this error message in Pre:
The variable 'T' referenced in parameter 'Source' in object '/FLOW/DOMAIN:Product/SUBDOMAIN:Subdomain 1/SOURCES/EQUATION SOURCE:energy' does not have one of the required prefixes: phase or particle.
PS: I define my solid as CHT
Old   June 7, 2006, 09:00
Default Re: Source term in energy equation
opaque
Dear macdidi,
The preprocessor is being "picky" that it should.. Just add the prefix to the variable T.. For example, if your solid list includes Copper, just pass the Copper.T variable to your User Fortran.
If that works, please let everyone here knows.
Good luck,
Opaque..
Old   June 7, 2006, 09:02
Joe
You need to disambiguate which phase the T refers too. I cant remember the exact syntax offhand but its something equivalent to: phase1.T rather than just T.
Old   June 7, 2006, 10:58
macdidi
Thanks I try youre sugestion and now it's working Thanks a lot
Old   April 15, 2017, 06:33
Mariem
mariema is on a distinguished road
hi could tell me what is the expression of term source in the equation of energy please ? i am modeling temperature in fortran too but i can't find the right form of term source
mariema is offline   Reply With Quote
Old   April 15, 2017, 18:53
Digging up an 11 year old thread.... You are lucky some of us old timers are still around.
If you want to set a source term from fortran then use your fortran to set a CEL variable and set the source term to that variable in CFX-Pre.
Old   April 17, 2017, 18:13
Mariem
thanks for replying Ghorroks.. Actually i don't use CFX-Pre. is there any way to write that subroutine in Fortran without using CFX-Pre?
Old   April 17, 2017, 18:38
Opaque will become famous soon enough
ANSYS CFX User Fortran is the last resource when it comes to custom models like a source term.
How complex is your source that requires UserFortran ? Does it require control logic ? Usage of internal variables, or not readily available functionality ?
CEL is the most common form to customize ANSYS CFX.
Opaque is offline   Reply With Quote
Old   April 18, 2017, 12:27
Mariem
i am looking for a simple expression of the source term due to chemical reaction.Normally it is dependant of the variables that I calculated in the same code like temperature,the reaction rate; the enthalpy of formation. it's like the expression above but it must depend of reaction rate not of mass flow
Old   April 19, 2017, 08:18
Say, you have a mixture named Mixture compose of 4 materials: Mat1, Mat2, Mat3 and Mat4, you can write the source term as
MySource = (Mat1.Static Enthalpy * Mat1.Molar Mass +
Mat2.Static Enthalpy * Mat2.Molar Mass +
Mat3.Static Enthalpy * Mat3.Molar Mass +
Mat4.Static Enthalpy * Mat4.Molar Mass) /
(Mixture.Density * Mixture.Cp)
No UserFortran needed.
Old   April 19, 2017, 11:58
Mariem
i am calculating the temperature in reactive medium of the methan combustion so i have to use the source term of the species conservation equation (that i already calculated) to calculate the source term in energy equation. but i don't find big change in the temperature profile when it's supposed to climb from 300 K to 1600 K.
Old   April 19, 2017, 15:53
If you are using ANSYS CFX for combustion, why do you need to reimplement the reaction mechanism ?
Are you solving a separate energy equation yourself ? ANSYS CFX does not solve for Temperature, but for Static Enthalpy and there is no need for reaction source terms whatsoever.
You are also trying to re-implement the Eddy Dissipation model which requires careful linearization..
As per writing the CEL you want, you need Mixture.Density, Mat1.Mass Fraction, Mat2.Mass Fraction.. A careful look at the ANSYS CFX documentation for CEL variables will list the available variables and how to prefix them for multi-component flows.
Old   April 20, 2017, 04:46
Mariem
Indeed, I'm writing a code in fortran i don't use ansys CFX So, the better way is to look at the Ansys CFX documenetation to check all variables.
If there any recommandation to a specific manual or link that demonstrate the Eddy Dissipation Model linearisation?
Old   April 22, 2017, 04:52
Mariem
Finally, i find the solution i didn't multiply the source term by the volume . Thanks for your instructions Opaque that give a result
Old   May 8, 2017, 23:47
Default decomposition reaction
  #15
Shuai Wang
cfx_ws1992 is on a distinguished road
I am modeling a decomposition reaction of methane hydrate in CFX.But I donot find a relevant model in CFX .What can I do let me achieve this reaction.
cfx_ws1992 is offline   Reply With Quote
Old   May 9, 2017, 20:23
  #16
Shuai Wang
I am trying to use interphase mass transfer to simulate chemical reaction.But I have no sucesse.
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
A source term in a vector equation CpCaniggia OpenFOAM Running, Solving & CFD 0 September 15, 2010 05:35
Bouyancy term in Energy equation CFDtoy Main CFD Forum 2 August 4, 2008 11:04
Mass transfer Term in Mixture Energy Equation CFDtoy Main CFD Forum 0 July 3, 2008 16:14
question about energy equation zhou FLUENT 0 February 23, 2004 23:55
