Buoancy Temp setting
Like Tree3Likes
  • 1 Post By Ali_91en
  • 2 Post By ghorrocks
Old   May 30, 2017, 09:09
Default Buoancy Temp setting
Ali karimi
Ali_91en is on a distinguished road
hey guys
i wanna simulate vertical and horizental heat exchanger and compare the thermal efficiency.
the domain is Real water with temp-dependant properties. i don know how to set buoyancy Ref temp, and i don have any idea about it! my inlet is 44c and 1 Lpm, and air flows over heat exchanger with 25c.
how should i set Buoy Ref Temp?
Svetlana likes this.
Life is fluid...
Ali_91en is offline   Reply With Quote
Old   May 30, 2017, 18:42
Set the buoyancy reference temperature to a typical temperature in the domain. So if your inlet is 44C then 44C sounds good.
Svetlana and Ali_91en like this.
Fluent Parallelization Problem After AC Power Dropped pawl Hardware 5 November 13, 2016 06:08
using chemkin JMDag2004 OpenFOAM Pre-Processing 2 March 8, 2016 22:38
[snappyHexMesh] determining displacement for added points CFDnewbie147 OpenFOAM Meshing & Mesh Conversion 1 October 22, 2013 09:53
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 21:58
Warning 097- AB Siemens 6 November 15, 2004 04:41
