Cavitation in pump-model test
Old   March 27, 2002, 08:59
Default Cavitation in pump-model test
opt
hi all I would like to simulation cavitation in end suction centrifugal pump and axial flow pump[using CFX Tasflow2.11.01], but I don't have result from model test. Wher's source that I can get it, from book, website...? Help me please. Regards
Old   April 5, 2002, 15:11
Default Re: Cavitation in pump-model test
Jean-François Caron
First thing to know is that the cavitation model in TASCflow does not permit simulate the real (physical) behavior of sheet cavitation encountered in pumps. THe real phenomenon is much more complicated that simply putting vapor pressure all around.
A good start for you would be the thesis of Hirschi of the EPFL (lmhwww.epfl.ch). There is a lot of other interesting stuff there on the cavitation subject (experimental and numerical) including my thesis ;-).
Best regards,
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 07:18
Advice about CEV cavitation model Matthieu CFX 1 October 27, 2018 10:00
about Subgrid-scale model impecca OpenFOAM Running, Solving & CFD 4 December 20, 2013 10:36
Re: Reference pressure for Cavitation model CFD USER CFX 5 June 3, 2012 07:01
Surface roughness setting for a model in wind tunnel test section Sharon CFX 12 March 31, 2009 13:09
