May 2, 2002, 05:42 |
Edit surface in Build 5.5
In CFX-Build 5.5 often have to use Edit/surface/edge match. If I look on my geometry with the "smooth shaded" button turned on, after that kind of editing the geometry looks sometimes very distorted. Is this just a visulaizing mistake of Build or does this step relly modify the geometry? (especially in my model i have truncated cones)
Thx Bogdan |
May 2, 2002, 09:15 |
Re: Edit surface in Build 5.5
Hi Bogdan,
This is just a vizualisation thing. All the edge match method really does is add a vertex to the edge of a surface to match vertices on a connecting surface, thus creating a trimmed surface (default color magenta). The underlying surface definition is still the same and can be recovered by using Edit>Surface>Dissassemble Robin |
Thermocapillary free surface flow | zakifoam | OpenFOAM Running, Solving & CFD | 10 | December 12, 2016 11:44 |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
Different surface incident radiation between surface and surface-shadow | Cortomaltese | FLUENT | 0 | July 16, 2011 07:00 |
Surface Tension Test Cases | sega | OpenFOAM Running, Solving & CFD | 2 | March 8, 2011 12:19 |
CFX 4.4 New free surface option | Viatcheslav Anissimov | CFX | 0 | April 3, 2002 06:27 |
