October 26, 2002, 12:55 |
a fortran problem in CFX
Hi all i am a CFX user. When i use the program of fortran in CFX, it occurs some problems......
Messages from CFX-4 Environment =============================== CFX-4 | Starting CFX-4.4 ... CFX-4 | Solver | runsolve4: Compiling user Fortran... CFX-4 | Solver | /CFX/CFX-4.4/bin/f77_w: f77: command not found CFX-4 | Solver | Compilation error in ../fort/usrbcs.f CFX-4 | Solver | runsolve4: An error occurred during compilation CFX-4 | Solver | runsolve4: Job completed CFX-4 | Solver | An output file was not produced CFX-4 | Solver | CFX-4 | Solver | Finished. CFX-4 | Solver | who can tell me how can i do ? it's a setup problem? Best wishes Roy Chen |
October 27, 2002, 06:46 |
Re: a fortran problem in CFX
In your fortran subroutine USRBCS.f a command is present that is not understood by the fortran compiler. Check your fortran code carefully for errors.
Astrid |
October 29, 2002, 07:15 |
Hi
I'd say that the CFX cannot find your compiler. as it says :'/CFX/CFX-4.4/bin/f77_w: f77: command not found'. so depending on the system you run it on, you should check if you can compile user subroutine with tutorial example and if you have proper f77 installation. matej |
November 14, 2002, 08:17 |
1.The version above Visual Fortran 6.0 is needed. 2.Uninstall your fortran compiler, reinstall it again.Take care of the enviroment variable.
cfx mesh problem... | mactech001 | ANSYS Meshing & Geometry | 0 | November 5, 2009 02:19 |
Ansys Workbench (CFX) bucket problem | njsavage | CFX | 1 | April 30, 2009 09:51 |
Ansys CFX bucket problem | njsavage | Main CFD Forum | 1 | April 30, 2009 09:48 |
Intel Fortran and CFX 11.0 | Rogerio Fernandes Brito | CFX | 4 | November 11, 2008 00:27 |
CFX 5.5.1 stirred tank and LES problem | Nishant | CFX | 2 | September 13, 2002 07:11 |
