The replication of Zwart cavitation model using CEL languages |
October 29, 2017, 15:43 |
linlin.geng
Rep Power: 8 |
I want to reproduce the mass transfer rate of Zwart cavitation model using the CEL language. the following languages is CEL which were used to replicate the cavitation model of Zwart.
If = if(pabsnc>=3574[kg m^-1 s^-2], pabsnc-3574[kg m^-1 s^-2], 3574[kg m^-1 s^-2]-pabsnc) Rob = 0.000001[m] F1 = sqrt((2/3)*(If /Water.density)) Cond = 0.01*3*Vapor.vf*Vapor.densitync*F1 /Rob Vap = 50*3*0.0005*(1-Vapor.vf)*Vapor.densitync*F1 /Rob Mass transfer = Vap -Cond but when i do the solve-process, the computation will diverage quickly. i do not know why. please give me some help. thanks a lot |
October 29, 2017, 17:23 |
Rep Power: 143 |
First of all, does the simulation run correctly when you use the built in cavitation model?
If that is OK then do some basic debugging: Send each of these variables to a user variable, defined to be CEL and set to the value of each of your expressions. Change your output file to write the results file every iteration. I would also add the residuals to the results file as that might have useful information as well. Then rerun the simulation until it crashes. Look at the results file and check all your variables are the expected values. |
Cavitation in Pure Ethanol | Pugnax | CFX | 4 | June 18, 2015 20:19 |
CFX Cavitation Model | kimotbwb | CFX | 10 | November 12, 2013 21:24 |
Errorin subroutine appeared when applying cavitation model | pitisrisuk | CFX | 1 | July 2, 2012 03:36 |
Cavitation model with non-isothermal flow | pitisrisuk | CFX | 0 | July 14, 2009 14:30 |
Cavitation Model Validation | Neil | Main CFD Forum | 0 | January 8, 2004 08:47 |
