Compiler for CFX4.4 on Linux cluster
Old   July 2, 2003, 02:55
Default Compiler for CFX4.4 on Linux cluster
Mads Bang
I know this has been discussed before in this forum, but maybe there is some news in respect to this subject.
Does anybody know if the Portland compiler is the only option for compiling double precision user FORTRAN on a Linux cluster, when I run CFX4.4? –or are there any free compilers out there which can do the job?
I think Jan Rusås raised the subject last time. So maybe you can comment with your experience on the matter.
Cheers, Mads
Old   July 2, 2003, 08:54
Default Re: Compiler for CFX4.4 on Linux cluster
Jan Rusås
Hi' Mads I can't answer your question, but what is the problem. a single Portland compiler is not so expensive, and I am sure that CFX must have an agreement with Portland so CFX user's can get it for an even lower price.
Old   July 4, 2003, 00:12
Neale
Yes, you must use the portland compiler for double precision. g77 does not support autopromotion through a compiler flag.
You might also try downloading the non-comerical version of the intel compiler, which has the right compiler options, but I don't think it has compatible name mangling with gcc/g77/portland (which are all compatible).
Old   July 16, 2003, 20:45
jeff
The main issue is that CFX-4.4 was compiled using the Portland compiler. Your code will compile with g77 just fine, but it won't link with the pre-compiled object modules of the CFX-4.4 engine. Last I heard (February), there were no plans to re-compile CFX-4.4 with the g77 compiler. Check with your support person.
Jeff
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
Linux Cluster Performance with a bi-processor PC M. FLUENT 1 April 22, 2005 09:25
Fortran compiler for Linux cluster Jan Rusås CFX 9 October 31, 2002 07:50
