How to composite this two surface together???
Old   July 22, 2003, 04:35
Default How to composite this two surface together???
adang
Hello everyone. I am now tring to build an airway geometry of human's lung. But there are something wrong with it. I have post it in the following address. Please help me to have a look at it. http://202.113.227.137/private/adang/airway/flange.html Thank you very much.
Old   July 22, 2003, 20:08
Default Re: How to composite this two surface together???
Robin
Hi Adang,
It looks like you have created the surface just fine. You still have to close off the ends, however, in order to generate a B-Rep solid. To do so, combine the curves at each end into a single closed loop using Create>Curve>Chain. You can then create planar trimmed surfaces using each loop as the "outer loop" in the Create>Surface>Trimmed form.
Regards, Robin
Old   July 22, 2003, 21:03
Adang
Hi, Robin
Thank you very much. With your great help I have got it.
Sincerely Adang
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 11:12
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 12:43
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
