February 12, 2018, 11:15 |
Applying thurst force to a face
Rep Power: 8 |
I am simulating drag over a rocket for different speeds. I need to apply a force representing the thrust of the rocket at the exhaust in order to determine correct pressure drag. I have tried searching for a way to do this, but with no luck. Does anyone know how this could be done? Thanks! |
February 12, 2018, 16:52 |
Rep Power: 143 |
Are you modelling the rocket as a moving body (so the force is required to get the rocket to move) or are you modelling the rocket fixed in its frame of reference and you want the rocket exhaust to be included so the entrained flow and drag effects are included?
I hope it is the fixed in its frame of reference case as that is the best way to do this simulation for most cases.
February 13, 2018, 00:07 |
#3 | |
Rep Power: 8 |
February 13, 2018, 00:11 |
Rep Power: 143 |
Excellent.
In that case the simplest approach for the rocket exhaust would seem to be an inlet boundary with the flow conditions of the rocket exhaust specified, presumably supersonic flow.
February 13, 2018, 01:55 |
Rep Power: 8 |
I will try that If I have thrust data for the rocket and I want it to be specified as an inlet - would the correct approach be to use normal speed and pressure as mass and momentum option, and then calculate the pressure equivalent to that of the exhaust from P=F/A, where F in this case would be the thrust force and A the area of the exhaust?
February 13, 2018, 04:24 |
Rep Power: 143 |
This web page seems to be rockets 101: https://www.grc.nasa.gov/www/k-12/airplane/rockth.html
In the thrust equation, if you know the force then you have m(dot), V and p(e) as unknowns. This assumes you know the geometry for the exit geometry. If you know the throat geometry then you can probably have a reasonable guess at the exit velocity from compressible flow equations. With any luck you know the fuel/oxidiser mass flow rate, then you have m(dot) and then you can solve for p(e).
February 13, 2018, 04:30 |
#7 | |
Rep Power: 8 |
February 13, 2018, 04:34 |
Rep Power: 143 |
The page appears to be from NASA, at their Glenn Research Centre. Any place with an excellent name like that has to be good.
[blockMesh] Internal walls of zero thickness | anger | OpenFOAM Meshing & Mesh Conversion | 23 | February 6, 2020 18:25 |
Output force distribution for each face on a patch | meh | OpenFOAM Post-Processing | 4 | October 20, 2011 11:07 |
[Gmsh] Import problem | ARC | OpenFOAM Meshing & Mesh Conversion | 0 | February 27, 2010 10:56 |
gmsh2ToFoam | sarajags_89 | OpenFOAM | 0 | November 24, 2009 22:50 |
Applying force in spectral element method | Steve | Main CFD Forum | 0 | January 29, 2002 00:30 |
