quadratic resistance co-efficient
Old   May 15, 2004, 13:25
Default quadratic resistance co-efficient
praveen rajaperumal
dear sirs i have a small query for u all. before getting into the queries i will breifly describe the problem this is related to the quadratic resistance co-efficient in a air filter for pressure drop calculation. here in this problem,we have a 3 domains inlet where we supply the mass flow rate outlet where we apply the avg static pressure BC filter where we supply the value of the K (quadratic resistance co-efficient)
my queries are 1. does k for the filter remain constant irrespective of the velocty value at the inlet to the filter.i have gone through the text in cfx help regarding this and found that it does vary with inlet velocity.ur comments on that sir.please see the attachment 2. please send it across,if u have any formula related to k for 3d flow.
with regards praveen rajaperumal cadem,tecumseh,hyd,india
Old   May 16, 2004, 18:30
Default Re: quadratic resistance co-efficient
Hi Praveen,
k is by definition a constant in this model. The documentation discusses momentum sources/sinks. The pressure loss will vary (obviously) but k will be constant.
Regards, Glenn
Old   May 18, 2004, 17:16
Phil
Small clarification... k can also be set as a CEL expression.
Quadratic resistance Coefficient Ramana CFX 4 November 26, 2012 16:25
Help in porosity for knitted fabric??? Linear or Quadratic resistance coeff SS460 CFX 13 September 22, 2011 11:43
Ship resistance tobino FLUENT 0 June 27, 2011 20:31
Quadratic Resistance Coefficient when energy source added. JoFFe CFX 3 October 27, 2010 08:42
Quadratic Resistance Coefficient Ramana CFX 0 January 2, 2006 03:43
