Is 2-d axi possible?
Old   December 1, 2004, 04:23
Default Is 2-d axi possible?
vladsi
Good Day, everyone! I wish to ask guru: Is 2-d axi possible? And how to set up it&
Vlad S I
Old   December 1, 2004, 10:09
Default Re: Is 2-d axi possible?
Ferdinand
Hi!
CFX is only a 3D solver. If you want to compute a 2D or an axisymmetric problem, you have to solve this as a 3D problem with periodic or symmetric boundary conditions.
Ferdinand
Old   December 1, 2004, 15:55
Robin
Hi Vlad,
2D is not available, but you can generate a mesh with one element in the circumferential direction and either symmetry or periodic boundary conditions on the side.
CFX-Mesh 9.0 will allow you to create a mesh like this from a revolved geometry. You can also generate a mesh like this in ICEM CFD by first creating your 2D mesh, then revolving the mesh about your axis.
Regards, Robin
Old   December 6, 2004, 05:40
Michael Bo
Hi Robin Does ICEM automatically manage to collapse the edge og the cells lying on the revolving axis? Or do I need to do something specific.
Old   December 7, 2004, 21:31
Robin
There is an option to merge the nodes at the bottom of the panel that does the revolve operation.
-Robin
Error in Axi symmetric model. binubtharayil FLUENT 2 August 5, 2009 16:01
doubts about axi symmetric moving reference frame and eers Main CFD Forum 0 July 9, 2009 15:53
BC's for following axi symmetric geometry.. eers Main CFD Forum 0 June 29, 2009 12:16
FoamMeshToFluent 2D axi frackowi OpenFOAM Post-Processing 1 February 12, 2008 20:45
Axi symmetric flow Emmanuel Resch Siemens 4 February 10, 2008 13:29
