change legend range in blade to blade view
Old   November 29, 2018, 11:30
Default change legend range in blade to blade view
vladimir krejci
Lada is on a distinguished road
I've run into a problem when creating a figure from a blade to blade view of the turbo mode.
How can one edit the legend range by playing a session file (perl script) and without the need of recreating the figure completely from scratch?
For a non-turbo mode based figures, the local objects contain the legend that can be modified from within a perl script using outputs of maxVal, evaluate, getExprVal...
When one wants to set the legend range for a flow angle though, there's a problem with what values get inserted in the legend. The functions return a value in radians, but the legend units are degrees.
How can one set the legend range so the values are reasonable in degrees then?
I don't think that calculating the radians to get the 'exact' value in degrees is the way.
Thanks.
Lada
Lada is offline   Reply With Quote
blade to blade view, legend range
[ICEM] Problem with Y+ elements in 3D blade mesh SlapGas ANSYS Meshing & Geometry 12 September 12, 2013 11:40
Problem in conducting CFD of analysis of wind turbine blade atulpat CFX 16 August 17, 2013 04:09
how to change angle of attack of a rotating blade in frozen rotor momo_sjx CFX 0 January 26, 2013 10:53
Compressor Blade Analysis in Ansys CFX LynchMobster47 Main CFD Forum 0 April 10, 2012 22:43
how to change blade leading angle of axial turbine dia aisa CFX 0 June 2, 2008 02:45
