vladimir krejci
Rep Power: 18 ![]() |
I've run into a problem when creating a figure from a blade to blade view of the turbo mode.
How can one edit the legend range by playing a session file (perl script) and without the need of recreating the figure completely from scratch? For a non-turbo mode based figures, the local objects contain the legend that can be modified from within a perl script using outputs of maxVal, evaluate, getExprVal... When one wants to set the legend range for a flow angle though, there's a problem with what values get inserted in the legend. The functions return a value in radians, but the legend units are degrees. How can one set the legend range so the values are reasonable in degrees then? I don't think that calculating the radians to get the 'exact' value in degrees is the way. Thanks. Lada |
blade to blade view, legend range |
Display Modes | |
[ICEM] Problem with Y+ elements in 3D blade mesh | SlapGas | ANSYS Meshing & Geometry | 12 | September 12, 2013 12:40 |
Problem in conducting CFD of analysis of wind turbine blade | atulpat | CFX | 16 | August 17, 2013 05:09 |
how to change angle of attack of a rotating blade in frozen rotor | momo_sjx | CFX | 0 | January 26, 2013 11:53 |
Compressor Blade Analysis in Ansys CFX | LynchMobster47 | Main CFD Forum | 0 | April 10, 2012 23:43 |
how to change blade leading angle of axial turbine | dia aisa | CFX | 0 | June 2, 2008 03:45 |
