April 24, 2019, 01:51 |
Modelling Connecting rod
rakesh p e
Rep Power: 9 |
HI,
I need to model a connecting rod as rigid body motion in a flow domain. I modelled crankshaft as giving specific rotation. can i add as connected motion by restricting the smaller end of conrod only with liner motion. Or individually through any specific equation Thanks in advance |
April 24, 2019, 15:11 |
Gert-Jan
Rep Power: 27 |
Please add a figure. A figure says more than thousand words...
April 26, 2019, 05:37 |
Rep Power: 143 |
I worked in IC engine modelling for 10 years so know exactly what rakesh is talking about
The only way of doing this is the derive the equations of motion of the conrod and make them define the motion. CFX does not have a rigid body solver (in terms of rigid bodies interacting with other rigid bodies) so you cannot generate this motion from the crankshaft and piston motions. Also - what approach are you using? Rigid bodies with dynamic remeshing? Or immersed solids?
April 26, 2019, 06:37 |
#4 | |
rakesh p e
Rep Power: 9 |
i solved it guys. ghorrocks you were correct. i am using immersed body approach. so added a rotary motion for crankshaft. added liner displacement for piston. general motion for conrod with the origin as piston pin moving with piston displacement and angular motion with respect to the piston pin. thankyou guys for helping me out |
CFD in Naval Hydrodynamics, Off-Shore and Wave Modelling with OpenFOAM | hjasak | OpenFOAM Announcements from Other Sources | 2 | February 13, 2017 04:59 |
Connecting rod bearing simulation. | mehcaecfd | STAR-CCM+ | 2 | June 28, 2016 05:30 |
connecting rod analysis | sahil patel | Main CFD Forum | 0 | May 17, 2013 08:33 |
Simulating an engine with piston and connecting rod | lovecraft22 | OpenFOAM | 0 | May 25, 2012 04:27 |
modelling thin rotating rod | doctsh | Fidelity CFD | 0 | November 7, 2009 03:17 |
