reference pressure confusion
Old   November 23, 2005, 05:27
Default reference pressure confusion
hiren
What is reference pressure in cfx. Is it absolute pressure. If it is absolute pressure then according to details in cfx Pabs=Pstatic+Pref. So, what is Pref. Suppose iwant to define pressure at inlet and my inlet condition is 3.75 bar then what should be given in ref pressure and for inlet condition what should be relative pressure.I have given ref pressure as zero and inlet pr as 3.75 bar. Is it right?
Old   November 23, 2005, 09:27
Default Re: reference pressure confusion
Nepal
How to setup the P_ref, you should lookup the manul(it depends on your simulation)
If you want to set P_static=3.75 bar at inlet case 1:you can set P_ref=3.75 , and P_relative=0 case 2:you can set P_ref=0.0 , and P_relative=3.75 Notes: all the pressure values in results are refered to P_ref
Installing OpenFOAM-1.5-dev on a cluster ZKM OpenFOAM Installation 4 December 25, 2010 15:59
OpenFoam-1.7.x on Suse 11.2 (64bit) does not compile val46 OpenFOAM Installation 4 August 27, 2010 03:43
G95 + CGNS Bruno Main CFD Forum 1 January 30, 2007 00:34
Building OpenFoAm on SGI Altix 64bits anne OpenFOAM Installation 8 June 15, 2006 09:27
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
