Inlet velocity profile as vector plot in CFX Post Processing
Old   July 9, 2019, 10:24
Default Inlet velocity profile as vector plot in CFX Post Processing
Qazi Shahzad Ali
Qazi_Shahzad is on a distinguished road
How to visualize "inlet velocity profiles" during CFX Post Processing" like the figure as attched, where vector arrows are proportional to magnitude of velocity.
File Type: jpg ansys-aim-aim-named-extention-bg-768x432.jpg (27.2 KB, 19 views)
Qazi_Shahzad is offline   Reply With Quote
Old   July 9, 2019, 19:25
That is straight forward post processing using CFD-Post. Just put a Vector object on the inlet and adjust the settings to suit.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   July 9, 2019, 23:37
Qazi Shahzad Ali
Dear Glenn Horrocks,
Thanks for the prompt reply. As per your expert opinion, I tried and got following results on inlet side of figure as attached, while adding a line. Also I tried by inserting the plane as well, but not getting what desired in terms of velocity gradient style as shown in right side of attached figure.
Want to increase length of top red arrows as compare to bottom blue arrows to look like visually a velocity gradient.
Need further guidance.
Thanks
Old   July 9, 2019, 23:43
As I said, you need to adjust the settings of the vector object to suit your preferences.
Also - your velocity only varies from 17.7 m/s to 18.3 m/s, so there is only a tiny variation in velocity over your current profile. So there is no velocity profile as seen in your desired plot in your results.
Defined inlet velocity is different with inlet velocity on CFX post jonpewpew CFX 2 November 2, 2017 16:40
UDF inlet velocity profile mismatch with Fluent ChristineL Fluent UDF and Scheme Programming 15 November 25, 2016 06:45
[swak4Foam] Scale discrete inlet velocity profile with groovyBC cboss OpenFOAM Community Contributions 1 June 20, 2010 13:02
FSI- Pipe- uniform velocity profile inlet Absy Main CFD Forum 0 April 6, 2010 03:01
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
