Python compatibility with CFx
Old   December 5, 2019, 06:05
Default Python compatibility with CFx
Jigs
jmex is on a distinguished road
Hello experts,
I have basic understanding of python 3.x version. I am looking for re-meshing technique for my problem. Is python 3.x version compatible to program? Or should i work with 2.x version.
Little confused here to start my work on the version of file.
Kindly suggest,
Thanks,
jmex is offline   Reply With Quote
Old   December 5, 2019, 15:45
CFX and ANSYS does not support python. At least not directly - CFX can be driven by the command line and you can send command line commands through python if you like. Alternately, I frequently use python to generate a batch, script or session text file to run CFX. But that is about all you can do.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   December 5, 2019, 21:09
Jigs
Okay thanks for your reply ghorrocks. I believe python version doesn't matter then, as python will execute changes in the file outside cfx and then cfx will run the file as per changes made.
Old   January 2, 2020, 02:28
Jigs
i have been trying with python but facing issue in cfx solver.
The error that i am facing is
Meshmod: Call to user defined mesh modifications failed. exited with return code 2.
what does this mean?
Old   January 2, 2020, 04:56
No idea. Giving us some context of what you are doing might help.
cfx, compatibility, python
CFX Treatment of Laminar and Turbulent Flows Jade M CFX 18 September 15, 2022 07:08
[OpenFOAM] paraview v4 - building with python - OF2.3.0, PVv4, Python 2.7 aylalisa ParaView 4 June 13, 2014 08:52
CFX pressure in Simulations problem nasdak CFX 1 April 14, 2010 13:22
PhD using CFX Rui CFX 9 May 28, 2007 05:59
FSI using CFX and ANSYS Bi Chang CFX 2 May 10, 2005 04:47
