Error in CFX-Post 10.0
Old   April 12, 2006, 15:41
Default Error in CFX-Post 10.0
Francesco
I ran a simulation with CFX. Everything looks ok. The .out file says the run has finished successfully and a .res file is created but when I try to load the .res file in CFX-Post (with the load results command) I get this error:
ERROR Unable to load this file. The only file types which CFX-Post can currently read are: 1) CFX Results or Definition files 2) CFX Mesh files 3) CFX-4 Dump files 4) CFX-TASCflow files (must have grd/rso, bcf and prm files) 5) CGNS Files (Error reading dataset G/TOPCAT)
Can anybody help me? I suspect this error has something to do with the fact that I actived the Output Control ->Results->Selected variables option in CFX-Pre. I say this because compared to the previous run I did I only changed this option and the previous run was worked ok.
Thank you Francesco
Old   April 12, 2006, 15:46
Default Re: Error in CFX-Post 10.0
opaque
Dear Francesco,
If you use the Selected Variables option, and want to use CFX-Post you must also include the mesh.. I think you forgot that..
Try again, and it should work..
Good luck, Opaque..
Old   April 12, 2006, 15:54
Francesco
Thank you for your yery quick reply. You are talking about the include mesh option in CFX-PRE right? I will certainly activate that option for the next run, but is there a way to use the results of the run I already did? I have the mesh file saved as a separate .gtm. Is it possible to load both the .gtm and the .res is CFX-POST?
Thanks again,
Francesco
Export CGNS with CFX 10.0 Luca CFX 1 December 29, 2010 06:09
Assign new variable in CFX Post Ben CFX 1 August 25, 2008 14:59
how to define pressure drop with CFX post alex CFX 0 September 20, 2007 17:31
CGNS mesh and CFX 10.0 tiziano CFX 0 February 5, 2007 07:13
Tecplot for CFX post processing pantangi goud CFX 2 August 24, 2005 16:42
