length integration
Old   April 18, 2006, 17:16
Default length integration
James
Hello, all
I am using the function calculator(cfx-post) to calculate the length integral of a variable on a streamline. However I can't find the mathematical description of this function in help document.
The question I would ask here is: if I have N lines in a streamline plot, will the LengthInt function give an average length integration value or a tatal integration value for all N lines?
Similarly, how does the lengthint work on a particle tracking plot?
Regards!
James
Old   April 18, 2006, 17:40
Default Re: length integration
Yes, I understand the lengthInt function integrates over the entire length of the body. If you have several streamlines it will integrate over all of them. If you want the integral over only a single streamline then create a streamline object with only a single streamline by giving it a single point as a start object for instance.
Old   April 18, 2006, 18:40
James
Hi, Glenn
The integral over only a single streamline probabaly is not useful(at least in my case). So I guess I need to take N streamlines, calculate the total integral, and then dividing N to get the average integral.
Thanks!
James
Turbulence length scale and integral length scale rizhang CFX 2 April 22, 2016 07:22
3D figures for 2D axisymmetric cases and length scale romantico FLUENT 0 June 1, 2010 18:17
Turbulent Characteristic Length/Turbulent Length Scale fluentnoob FLUENT 2 July 3, 2009 08:40
DPM: Particle Tracking Madhukar FLUENT 1 July 24, 2007 03:51
