March 13, 2020, 01:00 |
Error Restarting Transient Particle Tracking
George Pickering
I've been running a transient particle tracking simulation with fortran Particle User Routines for erosion calculations but have come across an error when trying to restart the simulation. I get the below error at the end of the 4th outer loop and it seems to be to do with the wall erosion routines not being transferred/located. Has anyone seen something similar before or know a workaround?
Parallel run: Received message from slave ----------------------------------------- Slave partition : 9 Slave routine : ErrAction Master location : PRB_MESSAGE Message label : 001100279 Message follows below - : +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | Message: | Unknown user routine ZN1 Parallel run: Received message from slave ----------------------------------------- Slave partition : 9 Slave routine : ErrAction Master location : PRB_MESSAGE Message label : 001100279 Message follows below - : +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | Message: | USER ROUTINE: I¦ ˜ could not be loaded. Please check the Lib- | rary Path, Library Name and Calling Name. For FORTRAN user routin- | es, the Calling Name should be in lower case. Parallel run: Received message from slave ----------------------------------------- Slave partition : 9 Slave routine : ErrAction Master location : PRB_MESSAGE Message label : 001100279 Message follows below - : +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | Message: | Stopped in routine PT_WALL_USER +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | The ANSYS CFX solver exited with return code 1. No results file | | has been created. +--------------------------------------------------------------------+ |
March 16, 2020, 01:26 |
George Pickering
The solution was as simple as changing the name of the input file (.def) so it was different from the result (.res), classic!
dispersion model with lagragian particle tracking model for incompressible flows | eelcovv | OpenFOAM Running, Solving & CFD | 54 | April 10, 2018 09:36 |
Particle tracking problem | sakurabogoda | CFX | 0 | January 25, 2013 21:47 |
Check particle impaction with User Fortran | Julian K. | CFX | 3 | January 12, 2012 09:46 |
restarting lagrange (particle tracking) simulation | dbdias | CFX | 0 | September 22, 2007 19:26 |
transient particle tracking | caty | CFX | 2 | March 30, 2005 08:22 |
