cfxsolve-Monitor Finished Run changes restart file
Old   May 12, 2006, 14:05
Default cfxsolve-Monitor Finished Run changes restart file
Karsten
If i open a restart file in cfx5solve via "monitor finished run" the file changes. It also grows approx. 14kb each time. I don't expect this behaviour because the data should not have been modified. This makes automatic backups more complicated. Ist this a bug or can it even destroy the restart files sooner or later?
Old   May 12, 2006, 14:09
Default Re: cfxsolve-Monitor Finished Run changes restart
opaque
Dear Karsten,
The solution has not changed, but cfx5solve also retrieves/store data in the results (you called restart) file. For example, that is just how it recalls which plots you were looking at the last time..
Will that explain it?
Opaque
Old   May 12, 2006, 14:22
Default yes but
Karsten
sorry you are right i meant the results file. The additional settings may be there but only opening and closing the file without changing any view or setting also changes and grows the file. So maybe the settings are duplicated each time. or something else...
Old   May 12, 2006, 14:46
Default Re: yes but
opaque
Dear karsten,
That is correct.. The cfx5solve GUI command, a.k.a Solver Manager, reinsert the last state back to the results file regardless if you have/have not made any changes..
If you are using UNIX, you could do as follows
tail -20 myresult_00x.res
and you will something like
VERY109163885 Y/SMSTATE VERY109173005 Y/SMSTATE VERY109182125 Y/SMSTATE VERY669191245 *ENDINDEX
where SMSTATE is the Solver Manager state..
is that behavior a major problem for you?
Good luck,
Opaque
Old   May 13, 2006, 05:01
Default Re: yes but
Karsten
Thank you for the precise answer. I am glad to see that this doesn't seem to affect the "real data" in the result file. It is not a major problem because i can export the run information i need and refrain from using the monitor finished run feature, now that i know what is happening.
Old   May 16, 2006, 09:07
Default Re: Try SP1
Patrick
The same problem appears in Pre; open a project, save it without any changes and the filesize grows... This bug disappears with SP1.
Old   May 16, 2006, 10:31
Default Re: Try SP1
opaque
Patrick,
Karsten observations are not related to the CFX-Pre misbehavior before SP1.. I hope Karsten is already running 10.0 SP1 anyways..
The ANSYS CFX definition/results files (*.def and *.res) contain historical data.. That is, uses of the Solver Manager, or the Definition File Editor are stored and new information is added to the file..Therefore, the file grows..
Opaque
tecio compilation errors in latest 1.6.x rsamuel OpenFOAM Bugs 2 June 25, 2021 08:10
[OpenFOAM.com] OpenFOAM 1.7.1 installation on LINUX UBUNTU 10.10 electrosin OpenFOAM Installation 40 May 31, 2016 05:11
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
