August 25, 2020, 00:15 |
How to Give Pressure Boundary Enclosed Fluid
Abid Khan
Rep Power: 8 |
I've a gas enclosed inside a container at 2bar and there is no inlet or outlet. I want to study temperature profile on different components of the container as a result of heat source inside and outside of the container. How to give this 2bar pressure to the fluid because Only boundary condition I can specify is symmetry and heat source inside the fluid. I tried setting reference pressure to 2bar but even then it shows message during the solution that no pressure is specified at any boundary condition. How can handle this case? Best Regards, Abid |
August 25, 2020, 02:11 |
M
Rep Power: 12 |
I didn't use it so far, but there is an option to set the Relative Pressure Level in Solver Control -> Advanced Options -> Pressure Level Information.
August 25, 2020, 06:42 |
Rep Power: 143 |
Are you sure this is a CFD problem? It sounds like a heat transfer thing as the fluid does not appear to be moving. Please correct me if I am wrong.
If it is just heat transfer then you can use CFX to do a thermal only model. Simply define everything as solids (including the stationary fluids) and you will have a heat transfer only model.
August 25, 2020, 08:24 |
Rep Power: 32 |
Careful with the boundary conditions.
If your thermal model only has the heat source, I assume you have the container walls set as adiabatic, correct? If that is the case, your system is not well defined since there is no reference temperature to anchor the solution to. Perhaps the container is not perfectly insulated, and there are some heat losses and you can then use the heat transfer coefficient option. The outside temperature will become the anchor then.
August 25, 2020, 12:33 |
#5 | |||
Abid Khan
Rep Power: 8 |
I am not clear how to define Pressure value inside the fluid domain because there there is no such boundary available and solver is giving warning as I stated in my initial post. Best Regards Abid |
August 25, 2020, 18:34 |
Rep Power: 143 |
The pressure level warning is just that, only a warning. A valid transient simulation is to define the pressure in the initial condition, but have a closed domain where the pressure can vary. If your simulation is like this then you can ignore the warning and proceed.
August 27, 2020, 06:40 |
#7 | |
Abid Khan
Rep Power: 8 |
August 27, 2020, 07:09 |
Rep Power: 143 |
If the gas starts at 2 bar and it a sealed, rigid container then the pressure will increase. CFX can model this, and in fact it is a good test case to use as there are analytical solutions to compare to and you can see what mesh, time step and convergence you need for accurate results.
You always set the reference pressure to a typical pressure in the simulation. So if it starts at 2 bar absolute and will get to about 4 bar absolute then a reference pressure of 3 bar would be appropriate (but setting the reference pressure to anywhere between 2 and 4 bar should be fine).
August 27, 2020, 11:45 |
#9 | ||
Abid Khan
Rep Power: 8 |
August 27, 2020, 19:12 |
#10 |
Rep Power: 143 |
All pressures (well, almost all) are relative to the reference pressure. So if your device starts at 2 bar absolute and goes to 4 bar, then set the reference pressure at 3 bar and the initial pressure as -1 bar.
August 28, 2020, 05:47 |
#11 |
Abid Khan
Rep Power: 8 |
Thank you very much for replies.
cfx, gas heating |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
interFoam (HELYX-OS) pressure boundary conditions | SFr | OpenFOAM Running, Solving & CFD | 8 | June 23, 2016 16:36 |
Setting rotating frame of referece. | RPFigueiredo | CFX | 3 | October 28, 2014 04:59 |
Concentric tube heat exchanger (Air-Water) | Young | CFX | 5 | October 6, 2008 23:17 |
