phase change of a dispersed fluid
Old   October 19, 2006, 03:56
Default phase change of a dispersed fluid
Alex phillips
Is it possible to model a phase change of a dispersed fluid? ie water dispersed in continous air to water vapour dispersed in continous air.
I have a tube carrying fast flowing hot air. 25m/s 510oC continuous fluid. Into this we are injecting dispersed water at 20deg C at the same velocity.
I have the model working nicely assuming that the water does not evaporate. We are injecting large amounts of water so the steam will very quickly condence back to water. So its effect on the global scale should be small. However it would be nice to model it correctly locally.
Old   October 23, 2006, 14:40
Default Re: phase change of a dispersed fluid
Camilo Costa
I work if to phase thermosyphons and have the same problem, but i think that don´t exist a model that previse tow phase change!
TwoPhaseEulerFoam and Boundary conditions raagh77 OpenFOAM Running, Solving & CFD 99 February 6, 2018 18:31
Two continuous phases and one dispersed phase modeling using CFX creddy_trddc CFX 1 August 13, 2013 22:23
Flash Process / Problem with thermal phase change model Ridley CFX 0 July 21, 2010 07:57
help needed about phase change Yanhu Guo Main CFD Forum 4 January 23, 2001 23:16
