how to reduce the lift force
Old   October 23, 2006, 10:23
Default how to reduce the lift force
aero
hi,
i am working on a car model (External flow, flow over a car body).
For aa given model lift force is positive.but in automotive lift force must be neagative (as per my knowledgek,is you have any suggestions regarding this please share it.).
can you tell me steps ( shange in shape of car body) to get negative lift force.
Thanks & with regards aero
Old   October 23, 2006, 11:10
Default Re: how to reduce the lift force
Robin
A lot of downforce comes from the acceleration of air under the body. I would first make sure you have modeled this correctly. Do you have the right ground clearance and did you specify an appropriate wall velocity to the ground?
Regards, Robin
Old   October 26, 2006, 22:05
TB
Hello... It depends on your car design, car speed, & flow conditions. Your results may be okay. Do you have some experimental data to compare with? Car manufacturer used to add bumper at front & rear, or even the wing at the back to increase the downward force.
Old   October 30, 2006, 10:41
aero
Thanks for participation.
i have Ahmed car model Experimental data.
i wanted to know about following concepts.
1. will increase in inclination result of increase in lift
force.
2. By reducing lift will it lead to increase in drag force.
can i have a website address or any material references which will help me to understand these concepts and carry out CFD work.
Force can not converge colopolo CFX 13 October 4, 2011 22:03
Saffman Lift Force: confused CFD_MAN FLUENT 5 September 9, 2010 04:51
Urgently Need the code of Lift force and VM force Kai Yan Main CFD Forum 0 July 16, 2008 07:07
Lift force or coefficient of lift Rola FLUENT 1 November 12, 2006 13:29
Saffman Lift Force CFD MAN Main CFD Forum 0 November 26, 2002 18:26
