Force as boundary condition
Old   February 20, 2007, 07:09
Default Force as boundary condition
Nicolas
I would like to ask how is it possible to set a constant axial force of 400 N on a boundary that has a type of a wall
Thank you
Old   February 20, 2007, 15:58
Default Re: Force as boundary condition
You might be able to do this using a moving mesh linked to a CEL function which evaluates the force on the wall and moves the wall to get the desired force. Setting it up should be straight forward but I suspect you will have problems getting it to behave numerically as you will have to tune the wall motion to converge on the desired force in a stable fashion.
Old   February 21, 2007, 03:35
Nicolas
You mean something similar with the moving mesh tutorial? which simulates a ball valve I think
Thanks a lot for your advice
Old   February 21, 2007, 16:13
Yes, similar to that tutorial. Get the force on the body and adjust the position of the wall until you get the force you want.
Setting outlet Pressure boundary condition using CAFFA code Mukund Pondkule Main CFD Forum 0 March 16, 2011 03:23
how to set up a wall boundary condition according to calculated wall shear stress? gameoverli OpenFOAM Pre-Processing 1 May 21, 2009 08:28
Spectral Method Boundary condition Deepak Main CFD Forum 1 February 25, 2004 09:48
Pressure Boundary Condition Matt Umbel Main CFD Forum 0 January 11, 2002 10:06
