June 13, 2021, 05:51 |
structural analysis Post processing results
Wanted
I recently started using the Ansys workbench for my thesis project, and I would like to ask what is the best approach to show the post-processing results?
For example, I had run a transient structural analysis simulation, and I got a result, i.e., deformed body, how will we compare the deformed body to the original geometry to find changes in volume or diameter, etc.? or is there any better way to show my results for people to understand in an easier way like to show in my thesis report I saw some approaches like using probes, but I am searching for a new and better way to show my results as a body got deformed, and this is the diameter change or volume change. |
June 13, 2021, 06:15 |
Rep Power: 143 |
This sounds like you are doing an FEA simulation, that is stress/strain. This is the CFX forum, it is not an FEA software. Try a forum about ANSYS Mechanical.
June 13, 2021, 06:36 |
post processing results
Wanted
First, i did cfx and got heat transfer coeff for that continuation transient thermal to calculate the cooling time of a body and then finally transient structural analysis to find how deformations were
do you know anything to help? |
June 13, 2021, 06:56 |
Rep Power: 143 |
The deformations are a FEA thing. Use the ANSYS Mechanical results objects to analyse these. For comments on how to do this try the Mechanical tutorials and forums. This forum is for CFX, so that covers the heat transfer side of things.
June 19, 2021, 05:36 |
Marcin
Rep Power: 13 |
U can see deformed on two ways
U can turn on undeformed wireframe Second U can define deformation factor to plot overscaled deformarion
Quick Tips and Tricks, Tutorials FLuent/ CFX (CFD) https://howtooansys.blogspot.com/ |
June 21, 2021, 15:36 |
Erik
Rep Power: 23 |
Hopefully you did the HTC correctly? What did you use for your bulk or "ambient" temperature in FEA?
By default, CFX uses the node adjacent to the wall to calculate HTC, which is mesh dependent and not the same as normal bulk temperatures. See the FAQs for more info on HTC. |
ansys workbench 19, post processing, structural analysis |
Coupling AcuSolve (Output .h3d results) with SimLab for Linear Static Analysis | gaddora165 | Main CFD Forum | 0 | March 5, 2020 13:16 |
Problem: Cannot get Results to work in post processing | mattsarg55 | Visualization & Post-Processing | 0 | August 5, 2019 10:50 |
How to combine ANSYS Fluent and Structural analysis? | diwakar | ANSYS | 2 | June 18, 2015 12:07 |
Automated post processing using CFD Post | shreyasr | ANSYS | 0 | January 28, 2013 06:21 |
Post Processing in FEM | Abhijit Tilak | Main CFD Forum | 0 | April 26, 2004 11:59 |
