August 3, 2021, 16:18 |
Rep Power: 32 |
I am not certain what kind of multicomponent fluid you are trying to model.
Hopefully, you are not bypassing the ANSYS CFX chemistry/reacting modeling capabilities. Here is an idea for you to try, at you own risk: 1 - Create the multicomponent fluid, say two materials A, and B, named "mixtureAB" 2 - Select "mixtureAB" for the Fluid definition for the domains you have in your setup 3 - Define the model you want to use for each material within the mixture as "Algebraic Equation" except for one. That material will be your ballast/constraint 4 - Input the expression that defines the Mass Fraction as a function of Temperature as you described in your original post. Be mindful and careful with the units/dimensions Run the simulation. Hopefully those expressions for Mass Fraction make sense, and the solution will converge.
Periodic Pressure drop | cfd_begin | CFX | 10 | May 25, 2017 07:09 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
Monte Carlo Simulation: H-Energy is not convergating & high Incident Radiation | volleyHC | CFX | 5 | April 3, 2016 05:41 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 20:09 |
