RGP
Old   April 25, 2007, 08:10
Default RGP
Stephan
I'm facing problems setting up a rgp-file for helium. The pressure range is 1 bar to 5 bar and temperatures reach from 7 K to 20 K - I'm dealing with a cryogenic application. The régime is supercritical and superheated vapor, respectively. Phase change is not expected and does not have to be considered in the model. Therefore neither the equilibrium nor the non-equilibrium model is required. Can the superheated vapor model (MODEL=3) deal with supercritical conditions? A nearly complete set of material properties is available from NIST. But how do I calculate (dp/dv)_T (p,T) for $table_6 or do you know another source beside NIST? What do I enter in the $PARAM line? Could you give some more detailed information about the saturation properties that need to be provided in each table? What do you suggest as the interpolation option? What actually happens when saturation curve clipping is performed?
thanks!
RGP file for CO2 Alessandro CFX 10 July 26, 2020 06:35
How to define a RGP file for liquid air? eis CFX 2 July 22, 2018 04:51
RGP file for liquid air eis CFX 0 April 22, 2010 10:34
what are these in property RGP table? prayskyer CFX 7 August 8, 2006 22:52
RGP table Atit Koonsrisuk CFX 1 January 10, 2004 11:14
