How to design a Vertical Pump
Old   May 17, 2007, 14:20
Default How to design a Vertical Pump
P. Castro
Hi Colleagues:
I want to simulate a vertical pump using Ansys CFX. I have the geomtry of the bowl and the impeller(negative) in Solidedge18 as solid *.part files. I am new simulating Hpumps. The thing is do I need surfaces or solid components to start the simulation? I want to create the mesh but I dont know if I have to mesh the whole solid or not. I have try to find some tutorials but I have not found anything yet on the internet. I want to mesh the bowl as one file and the impeller in a second file, then how can I connect them once they are discretized as meshes?
Thans
Old   May 18, 2007, 09:13
Default Re: How to design a Vertical Pump
Kumar
Export your part file as a parasolid file,import it in icem for meshing,connect them in solid edge if possible and after importing in icem create part names,save one file with one domain suppose your impeller(by deleting other geometry),mesh it,save the mesh,then open another and mesh it.define frozen rotor interface between rotatting domain and stationary domain.For FR interface u will require two surfaces from two geometries. And define one body point as orfn(in icem mesh) for solid volumes.
Old   December 16, 2009, 02:26
Ali Torbaty
AliTr is on a distinguished road
what you need is the fluid body. you can create the geomtery of your sump in workbench, then subtract the pump's body from that. this will give you the proper geometry for flow modelling.
AliTr is offline   Reply With Quote
Old   December 16, 2009, 19:05
Joshua Counsil
Josh is on a distinguished road
There are tutorials available to connect two separately meshed components.
This discusses the modeling and meshing:
http://people.civil.aau.dk/~i5mr/mhp/cm_tutorials.pdf
This discusses the setup and solution:
http://www.kxcad.net/ansys/ANSYS_CFX...als/index.html
The flow in a mixing tube is a good one to study the geometry process.
Josh is offline   Reply With Quote
Micro pump design / Diaphragm pump Michael Main CFD Forum 2 March 1, 2013 01:56
NUMECA-Optimization of pump design using FINE/Design3D mahdi balali Fidelity CFD 9 May 1, 2012 11:02
*Urgent*Please help about design centrifugal pump 2D or 3D*Urgent* tareqkh FLUENT 0 November 29, 2010 17:40
CFD Package for Water Pump Design !!! John Sheng Main CFD Forum 7 September 4, 2001 09:29
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 10:18
