Convert standalone CFx file to Workbench file
Old   June 9, 2023, 16:08
Default Convert standalone CFx file to Workbench file
Bhanu Swaroop Madiraju
Bhanu Swaroop is on a distinguished road
I know this might not be possible but is there anyway to convert CFX standalone file to Ansys workbench file or is it possible to open a cfd post result generated from standalone in workbench? I need to generate the performance maps for the case I am working. It's easier to generate them with performance map in workbench. If the conversion is not possible, how to generate compressor maps from cfd post? Do I have to solve the cases with different boundary conditions for a fixed rpm?
Bhanu Swaroop is offline   Reply With Quote
Old   June 9, 2023, 20:00
From Workbench you can import the mesh from a stand alone CFX file, and import the setup as a CCL file. You may be able to do it more directly as well.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Using PengRobinsonGas EoS with sprayFoam Jabo OpenFOAM Running, Solving & CFD 35 April 29, 2022 15:35
OpenFoam "Permission denied" and "command not found" problems. iyidaniel@yahoo.co.uk OpenFOAM Running, Solving & CFD 11 January 2, 2018 06:47
polynomial BC srv537 OpenFOAM Pre-Processing 4 December 3, 2016 09:07
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
[swak4Foam] funkySetFields compilation error tayo OpenFOAM Community Contributions 39 December 3, 2012 05:18
