June 17, 2011, 08:32 |
Parameteric Studies
Frank Weise
Rep Power: 17 |
Hi
is there a possibility to get a access to the Desgin Parameters from the DM in CFX-Pre or CFD-Post? E.g. i will simulate an tube. In DM, i design an section of the tube with an angel x and in cfd post i would like calculate the massflow of the whole tube so i need the angle x (360°/x*massflow). Or is there an other way to calculate the total massflow best regards Frank |
June 17, 2011, 08:45 |
Rep Power: 143 |
If you evaluate an expression in CFD-Post which determines your flow rate and set it as a parameter it can then be used as a parameter in workbench.
June 18, 2011, 04:25 |
Frank Weise
Rep Power: 17 |
Thanks, this is a good advice, it works fine . To this one i have a small problem. In one equation WB tolds me i've an error in unity. Because it isn't possible (speed*unitless should be speed). And sometimes i've got the right value. Could be a bug? I use Ansys 13 SP2.
So back to the original question, is there also a direct access to DM variables in CFX-Pre or CFD-Post? |
June 18, 2011, 07:22 |
Rep Power: 143 |
The way to pass variables from DM to Pre and Post is through WB. Looks like you have a problem with the way you set the variable up. Also I have no idea what your comment "In one equation WB tolds me i've an error in unity. Because it isn't possible (speed*unitless should be speed). And sometimes i've got the right value." means.
case studies, vortex shedding cylinder | Allan Cross | FLUENT | 2 | May 30, 2005 14:13 |
Vortex shedding case studies | Allan Cross | FLUENT | 5 | May 30, 2005 14:06 |
Analytical studies instead of computational | Ben | Main CFD Forum | 1 | October 12, 2004 08:06 |
Parametric Studies Using Fluent 6.1 | Jim | FLUENT | 0 | April 12, 2003 10:22 |
mixing studies | Kai Kang | Main CFD Forum | 1 | July 17, 2000 10:58 |
