Incompressible
Old   March 2, 2008, 08:57
Default Incompressible
selim
Hi, I want to simulate laminar transient flow with air. I want to use temperature independent flow properties and constat density. Air at 25 work here? Also the energy would be total or thermal?
Thanks, --Selim
Old   March 2, 2008, 11:59
Default Re: Incompressible
sam
For the incompressible solution, you will use the option of isothermal and use 25C as temperature with the laminar flow model.
Good Luck.
Old   March 2, 2008, 12:03
selim
My problem involves heat transfer I want to use temperature independent material properties. Thanks, --selim
Old   March 2, 2008, 17:00
Rogerio Fernandes Brito
just choose laminar flow, if you have low values of velocities! Try calculating the Grashof number (if you have natural convection) or Reynolds number (if you have forced convection).
Old   March 2, 2008, 17:04
donīt you forget to make a validation of cfx software with experimental data! I recommend you using hexa mesh!
Incompressible turbulence models: strange implementations? AleDR OpenFOAM 3 November 18, 2014 11:23
Hardware selection for steady/unsteady incompressible, turbulent and cht simulations maddalena OpenFOAM 2 July 13, 2011 08:55
Incompressible Ideal gas law Leverkin FLUENT 5 March 5, 2009 16:41
Abt: the speed of sound in incompressible flows jinwon park Main CFD Forum 3 August 21, 2008 20:44
Compressible vs. Incompressible formulations Fernando Velasco Hurtado Main CFD Forum 3 January 7, 2000 16:51
