February 28, 2024, 05:56 |
Radial bearing force - CFX and Fluent
Jiri
Rep Power: 13 |
Hi there,
I encountered the following issue: I am simulating a radial bearing. The geometry is simple: cylindrical region with radially shifted inner wall to obtain eccentricity. This region includes inlet pipe. All meshed together in ICEM as hexa mesh. Based on theory for given shaft speed and lubrication gap, the radial force is independent on density, because pressure force and viscous force are dominant, thus density goes away. This behaviour was confirmed in Fluent, I computed density 1000 kg/m3, 1 kg/m3 and 0.0001 kg/m3, and the force (Fx^2 + Fy^2)^0.5 is almost same, the results deviate negligibly. But when computing this in CFX, I have different results for density 1000 and 1. The difference is more than 200%-300%.. !! The results however get closer for density 1 and 0.0001. I verified the influence of reference pressure and others.... no idea yet. Computations run in CFX and Fluent are as follows: double precision, laminar, incompressible, isothermal, isoviscous... Thanks a lot.. |
February 28, 2024, 14:15 |
Erik
Rep Power: 23 |
Just checking, you are not including buoyancy/gravity in either case?
February 28, 2024, 16:54 |
Rep Power: 143 |
There are many, many details you need to get correct for you to get the correct results. So something is likely to be wrong in your CFX setup. You will have to do a close comparison between the CFX and Fluent models, including looking at the documentation about understanding exactly what all the options mean.
February 29, 2024, 03:49 |
Jiri
Rep Power: 13 |
Well, I think I get it.
Velocity - pressure coupling solver is the culprit. It is very surprising to me. Both cases are converged, but to a different result. It again opens the question regarding the local minima of N-S equations system. Different solvers - different results, although both converged. See the attachment. To evelica: no I do not consider gravity. |
February 29, 2024, 17:28 |
Rep Power: 143 |
Make sure you know what you are dealing with here. The option you changed is the Rhie-Chow pressure to velocity coupling. You did not change the CFX coupled solver for the linear equations (which is what most people think of when they think solver coupling).
You should have a close read of the documentation regarding Rhie-Chow and P-V coupling and work out which approach is most suitable for your case. As you have an unusual case (likely low Re number, highly rotational flow) a non-default Rhie-Chow may be more suitable.
Fluent Meshing for CFX opinions | siw | CFX | 1 | April 25, 2022 06:55 |
CFX vs. FLUENT | turbo | CFX | 4 | April 13, 2021 08:08 |
Comparison of fluent and CFX for turbomachinery | Far | CFX | 52 | December 26, 2014 18:11 |
Different result in CFX and fluent for mass trans.? is segregated better? | ftab | CFX | 7 | September 27, 2012 07:57 |
CFX or Fluent for Turbo machinery ? | Far | FLUENT | 3 | May 27, 2011 03:02 |
