March 19, 2024, 04:05 |
rigid Body levitation
Frank Weise
Rep Power: 17 |
I try to make a small sphere (density slightly higher than water) levitate in water. The sphere is being streamed from below. In a transient simulation, I get absurdly high accelerations of the ball at the beginning and the smaller I make the time steps, the higher the acceleration becomes. Is there a way to dampen this? best regards Frank |
March 19, 2024, 16:46 |
Rep Power: 143 |
High accelerations on start up are not a problem as long as they settle down quickly to a sensible value. This start up transient should sort itself out quickly and end up only being a insignificant blip at the start of the results. So I would let your simulation continue and see if it progresses well.
March 20, 2024, 03:25 |
Frank Weise
Rep Power: 17 |
I then managed it. The simulation is running. Unfortunately, I had to use the "General Coupling Control" to get it stable. But when I use it, the automatic timestepping doesn't work.
Whole domain movement rigid body with overset | pj_design | OpenFOAM Running, Solving & CFD | 1 | March 23, 2024 08:52 |
Specifying Mesh Deformation & Rigid Body Motion on a Cell Zone Using UDF | zx9cp | Fluent UDF and Scheme Programming | 3 | July 11, 2023 05:14 |
Rigid body in creeping flow - COMSOL | MultiPhy | CFD Freelancers | 1 | June 8, 2017 01:38 |
rigid body motions- no external force | armin najarian | Main CFD Forum | 1 | July 6, 2016 03:19 |
Rigid body motion on transient fluent mrf | ghost82 | EnSight | 4 | September 6, 2014 11:24 |
