rigid Body levitation
Old   March 19, 2024, 04:05
Default rigid Body levitation
Frank Weise
FrankW is on a distinguished road
I try to make a small sphere (density slightly higher than water) levitate in water. The sphere is being streamed from below. In a transient simulation, I get absurdly high accelerations of the ball at the beginning and the smaller I make the time steps, the higher the acceleration becomes. Is there a way to dampen this?
best regards
Frank
FrankW is offline   Reply With Quote
Old   March 19, 2024, 16:46
High accelerations on start up are not a problem as long as they settle down quickly to a sensible value. This start up transient should sort itself out quickly and end up only being a insignificant blip at the start of the results. So I would let your simulation continue and see if it progresses well.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   March 20, 2024, 03:25
Frank Weise
I then managed it. The simulation is running. Unfortunately, I had to use the "General Coupling Control" to get it stable. But when I use it, the automatic timestepping doesn't work.
Whole domain movement rigid body with overset pj_design OpenFOAM Running, Solving & CFD 1 March 23, 2024 08:52
Specifying Mesh Deformation & Rigid Body Motion on a Cell Zone Using UDF zx9cp Fluent UDF and Scheme Programming 3 July 11, 2023 05:14
Rigid body in creeping flow - COMSOL MultiPhy CFD Freelancers 1 June 8, 2017 01:38
rigid body motions- no external force armin najarian Main CFD Forum 1 July 6, 2016 03:19
Rigid body motion on transient fluent mrf ghost82 EnSight 4 September 6, 2014 11:24
