Head pressure loses problem.......
Old   March 24, 2008, 15:04
Default Head pressure loses problem.......
krecki
Hi all. I'm new in CFX Could you advise me please how should i set my BC to work out the head pressure loses in my simulation? I have a valve geometry inside simulation and have tried to set transient type of simulation. My initial boundary condisions were set all for zeros ( pressure , velocity) and my inlet pressure was set to 1000[Pa] , Outlet was set to 0[Pa], reference pressure was set to 0[Pa] . With BC set like that my results didn't capture any pressure drop on inlet side. It was constantly 1000[Pa] thru the 30[s] period which i set in transient simulation with 1[s] timestep. I'll be gratefull for advice.
Regards
Tom
Old   March 25, 2008, 17:46
Default Re: Head pressure loses problem.......
Steven
How have you set the conditions of the walls? They should be set with a value of <no slip> to simulate the friction of teh pipe walls? Cant be sure form your description but you could be pumping through a frictionless pipe!? Either that or youve invented the best pipe ever
Steve
stagnation pressure boundary problem mbgnfrx2 STAR-CD 2 November 25, 2012 23:55
Pressure calculation problem maolongliu OpenFOAM 1 August 15, 2010 08:05
pressure gradient term in low speed flow Atit Koonsrisuk Main CFD Forum 2 January 10, 2002 10:52
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 13:19
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 15:00
