April 12, 2024, 04:27 |
cgns format in steady state
Meysam
Rep Power: 6 |
I have a problem showing the ISO surface result in a steady-state calculation. As you know, in the steady state calculation, there is just one last Time step, which is not enough to make an animation. I saved some variables in the .cgns format for every Iteration. But I cannot import or add the saved result to time steps like transient calculations. However, it does not work. Is there another possibility? regards, |
April 12, 2024, 04:50 |
Rep Power: 143 |
You can always save backup files every few iterations and use them to make an animation. But make sure you know what the animation is showing - it is showing the evolution of the simulation towards convergence. It does not show a transient simulation.
April 12, 2024, 05:07 |
#3 | |
Meysam
Rep Power: 6 |
Thanks for your Feedback. Can you tell me how I should import the backup in Post in this case? I tried to import, but this format was not found. best, |
April 12, 2024, 05:13 |
Rep Power: 143 |
File/Open, that is all which is required.
April 12, 2024, 05:47 |
Meysam
Rep Power: 6 |
As can be seen in the photos, There is a problem loading the result.
File-->Load Result-> .cgns What is the Solution? best, |
April 12, 2024, 08:11 |
Rep Power: 32 |
I am confused. Why are you post-processing Ansys CFX results in CFD-Post using an alternate format?
The Ansys CFX format contains whatever CFD-Post needs. Any other format can only contain the same or LESS. You are taking chances working this way. Alternate formats are there to be used on alternate post-processors, sometimes with a drop in functionality because not everything is guaranteed to be transferred.
Effect of initial condition for steady state vs Transient | prasa | ANSYS | 0 | August 22, 2018 04:45 |
Domain Reference Pressure and mass flow inlet boundary | AdidaKK | CFX | 75 | August 20, 2018 05:37 |
Time Increment Significance in Steady state FEM CFD solvers? | Abhya | Main CFD Forum | 1 | October 14, 2015 20:07 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
About the difference between steady and unsteady problems | Lisa | Main CFD Forum | 11 | July 5, 2000 14:37 |
