Hybrid mesh in 2D in ANSYS ICEM CFD
Old   December 17, 2008, 10:23
Default Hybrid mesh in 2D in ANSYS ICEM CFD
Alex
Hey,
I am currently running simulations on an airfoil. I would like to create for that a hybrid mesh in ANSYS ICEM CFD. However, I dont know how this is possible. The mesh in the close vicinity of the airfoil is stuctured and I want to fill in the rest of the space with triangles. Could someone help me on that? Thank you in advance.
Alex
Old   December 18, 2008, 08:13
Default Re: Hybrid mesh in 2D in ANSYS ICEM CFD
Rogerio Fernandes Brito
Create the blocks where u want to make the hexa mesh and create the tetra mesh using the option "merge". I think it will work out.
I tried to do that, but it appeared a lot of "holes" inside the mesh"
If you want to build this mesh on this simple geometry...
http://www.4shared.com/file/73524138...8_11_2008.html
After that, tell me if u got it!
Old   December 19, 2008, 10:00
Alex
What I do is to first create the structured mesh in the vicinity of the airfoil. Then I would like to fill in the rest of the area with triangles. Moreover, I would like the mesh to become coarser as the distance from the airfoil increases.
You said that I should use the option "merge", but do u mean "merge interactive" or "merge meshes"? I know that it is possible to merge meshes in the 3D case, but what about 2D?
Thanx in advance.
Alex
Old   December 22, 2008, 04:17
Bart
Why use ICEM for that? If you use cfx-mesh for that with inflation layers you will get just that in 2D. You can extend your inflation layers as far as you like as long as you have at least one layer of tet cells between the inflation layers and you boundary condition. Better yet; put an inflation layer on your boundaries.
Bart
Old   December 22, 2008, 05:10
Alex
I am not familiar with CFX and I dont know if it is even available at my university. Is it not possible to use ICEM for that? I am already very familiar with this program, making structured meshes. Thank you in advance.
Alex
Old   February 1, 2009, 12:29
nils
Hi Alex I am also trying to Built a hybrid Mesh in Icem, my farfielt is pure Hex and now i want to create the farfield in tetra (it is a 3D problem), the merge Mesh tool doesn´t work well, I am looking for a method whre i can start the mesh generation from the existing hex mesh, without using internal faces. Is there anybody who knows if it works in ICEM ???
Nils
Old   March 5, 2011, 16:32
Ugly Kid Joe
vmlxb6 is on a distinguished road
I know its a bit too late but I need help with this also. I am simulating a flow over a cylinder (2-D). The cylinder is moving i.e it is a 1 way FSI problem. I need an excellent mesh around the vicinity of my Cylinder walls. I need a structured mesh around the cyl and tri meshes in the far field.
Can anyone pls help.
vmlxb6 is offline   Reply With Quote
mesh from icem cfd to cfx, how? Rogerio Fernandes Brito CFX 17 April 18, 2016 03:34
Learn ANSYS ICEM CFD easy_astronaut ANSYS 2 December 15, 2013 15:34
[Commercial meshers] Mesh conversion from Ansys ICEM fabian_korn OpenFOAM Meshing & Mesh Conversion 3 February 24, 2010 08:19
----------------2D mesh with ICEM CFD Abir FLUENT 2 September 12, 2008 23:55
Mesh from ICEM CFD to CFX ! Error ! Why ? Thanks ! Vu Trinh Tuan CFX 11 March 28, 2005 19:04
