January 21, 2009, 12:48 |
what is ACA on Meridional surface?
for example, pressure ACA on Meridional surface. I am running a compressor simulation. What does ACA stand for?
Thanks! |
January 25, 2009, 06:47 |
Re: what is ACA on Meridional surface?
Area Circuferential Average
CFX makes a new variable whenever you calcuate an average value on a meridional surface, and it prefixes the variable with LCA, ACA, or MCA based on what type of circ. averaging was performed (Length, Area, Mass). |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 11:05 |
[Gmsh] boundaries with gmshToFoam | ouafa | OpenFOAM Meshing & Mesh Conversion | 7 | May 21, 2010 12:43 |
