Jet fan and Tunnel simulation
Old   April 6, 2009, 12:30
Default Jet fan and Tunnel simulation
ahlo7 is on a distinguished road
I am simulating a jet fan in a tunnel.
The fan is set in a simple way: a cylinder with one end as entrance of the jet fan and another end as exit of the jet fan.
A tunnel air domain was cut by this fan cylinder and set the entrance of jet fan as an outlet and the exit of the jet fan as an inlet of the domain.
Two ends of the tunnel were set as openings with static pressure zero Pa.
The jet fan has 26m/s velocity with area 1.16m^2
The tunnel section is 45m^2 and 300m length.
The simulation went well and converged well, but the result looks not realistic.
The tunnel average velocity is 20m/s! It needs a huge power to drive this flow. The jet fan obviously has a small portion of such a power. Where it was wrong...?
Turbulence model used is k-e with 5% intensity
Thanks for any help
Ahlo
ahlo7 is offline   Reply With Quote
Old   April 6, 2009, 16:44
Michael P. Owen
michael_owen is on a distinguished road
I'm not sure I understand the problem set up, but it sounds like you may have a poorly defined problem that may admit multiple solutions. You say that you have 0 static pressure openings defined at both ends of the tunnel? The wind can blow through the tunnel at any speed in a case like this.
michael_owen is offline   Reply With Quote
Old   April 9, 2009, 10:18
Thank you, Michael
It is possible the BC were not well defined and it risks in having multiple solutions.
I assumed there is friction induced pressure drop along the tunnel, and this will somehow limit the air speed although with end of the tunnel have Pstatic=0. I added some back pressure at exit end of the tunnel, it improved, but velocity still looks high.
Any Suggestion to set better BC?
Old   April 15, 2009, 07:02
Tassi
Tassi is on a distinguished road
Hi
Didn't understand you description that well. I suggest you give outlet BC as velocity or mass flow and inlet as Static Pressure.
Tassi is offline   Reply With Quote
Old   April 16, 2009, 02:55
Pratik Mehta
pratikmehta is on a distinguished road
I would suggest that you attach a .jpeg of your case describing your domain in that image . To me also it not clear how your problem is setup and the way you are defining your boundary conditions
Best regards
Pratik
pratikmehta is offline   Reply With Quote
Old   June 10, 2010, 06:12
Default jet fan boundary condition
abbasmh10 is on a distinguished road
hi there
i was wondering if i can find help with my issue. i ve been using fluent in simulation of ventilation in rooms. my main task is to simulate a garage ventilation model using gambit and fluent. concerning the jet fans, i wonder wht kind of boundry condition shall i insert in the inlet and outlet. shall i treat the inlet as PRESSURE OUTLET, and outlet of the fan as VELOCITY INLET? or there is another boundary identification concerning the fan? thats for the normal ventilation, and soon i ll send a question concerning the smoke extraction. i hope i ll find help with that. thank u in advance
abbasmh10 is offline   Reply With Quote
Old   June 10, 2010, 08:04
Doesn't Fluent have a fan boundary condition. Not sure. You are asking the wrong forum, this is the CFX forum.
Old   March 7, 2012, 10:25
christopher
chvolk is on a distinguished road
Hi, I want to make a jet fan simulation in a tunnel too, but I'm new in openFoam and a I really need some help. What solver do you use to get the simulation? How do you set the boundary conditions? Can you send me some tutorial or information about jet fan simulation ? or can you send me your work? I'll be very grateful!
chvolk is offline   Reply With Quote
Old   November 12, 2019, 23:40
Default Some considerations in tunnel ventilation analysis using CFD
Hareesh R Iyer
Haga is on a distinguished road
I happened to come across this thread while searching for some info regarding analysis of a jet fan in tunnel using CFX or Fluent. Here are some aspects that we need to consider for the same.
  1. For simple setup, the finite volume domain can be easily modeled as Eulerian, not as Lagrangian since only the fluid (air) volume moves.
  2. Pressure and temperature data at portals may be included real time to ensure natural air flow.
  3. Fire can be setup as a STEP input for longer transient simulations.
  4. Jet/axial fan exit velocity will always be higher than the tunnel air velocity whenever fan is operated.
I am also in search of steps to analyse tunnel ventilation system using CFX. If anybody have done some work in this regard, please share the knowledge.
Haga is offline   Reply With Quote
Old   November 13, 2019, 04:54
Can you explain what your question is?
ANSYS support has some examples of tunnel ventilation. There are some literature and journal articles written by CFX/ANSYS people on this which might be useful for you. Contact ANSYS support to get them.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
wind tunnel simulation Andres Paez FLUENT 1 August 15, 2008 00:17
Push/Pull blower simulation, open wind tunnel Roland CFX 3 February 20, 2008 16:42
I need comments from my 1st run simulation...plz fadly CFX 8 October 8, 2007 05:04
meshing fan blade in tunnel... fadly CFX 4 August 10, 2007 16:52
Jet Fan Model sudharsan FLUENT 0 September 15, 2003 05:52
