multiphase flow heat transfer
Old   April 16, 2009, 02:33
Default multiphase flow heat transfer
King
yeeking86 is on a distinguished road
I am currently working on a model where I have both water and air acting as fluid. The water flows through a microchannel with air trapped in the gaps preventing the water from flowing into the gaps. I need to find out the heat transfer between the water and the microchannel. I am using Volume of Fluid (VOF) method to model the fluid. When I tried to solve it says error solving multiphase flow. Can anyone tell me how to solve this multiphase flow?
Thank you
yeeking86 is offline   Reply With Quote
Old   April 16, 2009, 08:29
Have a look at the free surface flow over a bump tutorial. This will show you the basics of how to set up this type of model.
How to check Heat Balance in heat transfer like mass balance for flow mahendra OpenFOAM Post-Processing 15 February 8, 2012 10:19
No results for solid domain Gary Holland CFX 10 March 13, 2009 03:30
How can I increase Heat Transfer at Domain Interf? B.Simon CFX 3 October 28, 2008 18:53
axial flow around a cylinder -heat transfer model? Ralf Schmidt Main CFD Forum 1 March 21, 2006 08:54
Periodical Oscillating flow heat transfer S.L.ZHOU Main CFD Forum 0 September 20, 2000 22:22
