problem while transferring from 32bit to 64 bit
Old   March 20, 2009, 01:05
Thumbs down problem while transferring from 32bit to 64 bit
tangqh is on a distinguished road
I have successfully finished a simulation with cfx11.0 32bit(converged).
however, when I read in 64bit cfx11.0, and start calculation, the iterations terminated after 5 to 6 steps. and the error information are:
ERROR #004100025 has occurred in subroutine SCL_RESCH. |
| Message: |
| A floating point overflow has occurred. Check solver |
| parameters, boundary conditions and mesh quality. The |
| calculation will be terminated. |
| Note: if this error occurs at the first iteration, that may |
| be caused by the initial guess, e.g., a zero initial |
| velocity and zero dynamic viscosity. |
| Traceback: |
Parallel run: Received message from slave
Slave partition : 5
Slave routine : SCL_RESCH
Master location : RCVBUF,MSGTAG=999999
Message label : 004100025
Message follows below - :
| Message: |
| An error has occurred in cfx5solve: |
| The ANSYS CFX solver exited with return code 123. No results |
| file has been created. |
End of solution stage.
tangqh is offline   Reply With Quote
Old   January 26, 2010, 12:10
Eoghan
Magsy is on a distinguished road
I seem to be having the very same problems?
Did you ever get to the bottom of this?
Thanks.
E
Magsy is offline   Reply With Quote
Old   January 26, 2010, 23:37
sorry, not yet, but you may reinstall cfx11.0 and try again
UDF Compiling Problem (64 bit machine) woo meng wai FLUENT 0 October 23, 2007 23:14
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Problem in Tutorial problem of fluent Phanindra FLUENT 5 April 17, 2007 09:57
problem with using colocated code Jack Main CFD Forum 0 December 15, 2002 00:15
