coefficient drag
Old   May 17, 2010, 14:52
Default coefficient drag
JEHERZ is on a distinguished road
hello
I am new to CFD, conducted an analysis of flow around a vehicle, I want to determine the coefficient of drag and lift
the speed is in the z-axis direction, is appropriate to draw "Force Z" in the body of the vehicle and use the maximum value and apply it to find the drag coefficient.
such as graphing the drag coefficient?
which method should I take?
need help!!!!
thanks
JEHERZ is offline   Reply With Quote
Old   May 17, 2010, 18:39
What do you mean by the maximum value of the force Z? The force probably is not steady so the force Z will not be constant - unless you have managed to get a turbulence model to average all the flow back to a steady state, which is unlikely to be accurate.
Old   May 25, 2010, 08:38
Default Plot coefficient drag??
My question is how to plot the drag coefficient.
Apply this formula:
force_z()@BODY / (0.5*density*Velocity^2*Area)
I'm new to CFD, I can not plot, I have to do?
Sorry my English is not very good
many thanks
Old   May 25, 2010, 19:09
Define a monitor point with the CEL expression. Then you can see how the drag coefficient moves as the run progresses. Or you can do it in CFD-Post.
Old   February 9, 2012, 03:33
Talking
How do you do the CEL expression??
or
How could do it in CFD-post?
I can't do this expression, I need you help me, please!!!!
Old   February 9, 2012, 06:28
Put the expression posted above in as a monitor point in a solver run, or put it into the function calculator in CFD-Post.
Drag Coefficient Convergence Problem John FLUENT 18 June 24, 2023 09:22
Drag coefficient for parcels in dieselFoam sebastian_vogl OpenFOAM Running, Solving & CFD 5 December 31, 2008 12:19
Automotive test case vinz OpenFOAM Running, Solving & CFD 98 October 27, 2008 08:43
Energy dissipation and Drag coefficient Freeman Main CFD Forum 10 January 27, 2006 07:42
drag and lift coefficient Noé Siemens 5 July 13, 2004 10:21
