June 16, 2010, 12:33 |
Error in one of the tutorials
Gabriel
I'm learning to use the CFX and I'm resolving the tutorials of the program. I found something strange in the tutorial number 22 - Fluid Structure Interaction and Mesh Deformation. I followed all the instructions, but when I start the simulation it's stop after 5 iterations with two errors that I transcribe here. I would like to know why it is happens. --------------------------------------------------------------------+ | ERROR #002100027 has occurred in subroutine cNWDIST. | | Message: | | At least one highly skewed element has been detected on a wall | | boundary, leading to an unreliable near-wall distance calculation | | for the turbulent wall functions. The solver will continue | | to execute, but convergence and/or accuracy may be affected. | | Please consider improving the mesh quality. The coordinates of | | the element face are ( 0.2000E+01, 0.9085E+03, 0.5000E-01 ). +--------------------------------------------------------------------+ | ERROR #002100012 has occurred in subroutine cVolSec. | | Message: | | A negative ELEMENT volume has been detected. This is a fatal | | error and execution will be terminated. The location of the first | | negative volume is reported below. | | Volume : -0.5436E-02 | | Location : ( 0.21975E+01, 0.72669E+03, 0.50000E-01) |
June 16, 2010, 13:15 |
Attesz
hi,
you meshed your domain wrong. read the tutorial carefully and mesh it again and , it should work. Regards |
June 17, 2010, 10:19 |
Gabriel
Thank you for your help, I read the tutorial again and found my mistake.
December 3, 2016, 04:23 |
Abhishek
please tell what was the mistake and how you corrected it. i am having the same error for the tutorial.
Population Balance Model Tutorials | sreepriyav | FLUENT | 2 | January 20, 2011 05:00 |
OpenFOAM tutorials w/o foamX | kriz | OpenFOAM | 3 | April 19, 2010 11:40 |
Install tutorials | jonlemur | OpenFOAM Installation | 4 | August 8, 2007 14:15 |
tutorials for icem-cfd v4.1 | vince | Main CFD Forum | 0 | August 23, 2003 15:25 |
Where can I find Airpak help doc. and tutorials? | Hotlood Wong | FLUENT | 3 | April 23, 2001 03:55 |
