CFX-Pre starting problem
Old   June 29, 2017, 05:16
Default CFX-Pre starting problem
Metternich is on a distinguished road
Hello guys,
i installed ANSYS 17 on ubuntu 16.04. The installation works fine and i can use ICEM, CFX-Post, TurboGrid, Solvermanager ...
Only CFX-Pre doesn't work.
Everytime i try to start i get following error:
Warning: ExternalPhysicsQueries - attempt to register ExternalPhysicsInterface more than once!
Invalid float bound in "PARAMETER VALUE" data for Adaption Target Residual
terminate called after throwing an instance of 'cue::PhysicsException'
what(): Invalid float bound in "PARAMETER VALUE" data for Adaption Target Residual
An error has occurred in cfx5pre:
/usr/ansys_inc/v170/CFX/bin/linux-amd64/PreGui_ogl.exe was interrupted by
signal ABRT (6) and dumped core
Aborting due to unexpected error:
comm::error: GUIInterface::waitInput - Unexpected end of transmission from GUI.
I already tryed deleting .cfx folder, installing libmotif4, editing etc/hosts ... but nothing worked. I really don't understand the error.
Any Help would be lovely.
Thanks
Metternich is offline   Reply With Quote
Old   June 30, 2017, 09:46
update:
I am able to start cfx5pre in line mode. But i cant start ist with gui.
cfx5pre -gr mesa
doesn't work too...
pls help. i am totally desperated.
Old   July 4, 2017, 02:36
Maxim
-Maxim- is on a distinguished road
as far as I know, ubuntu is not supported by Ansys. You probably have to be happy that you can start it via command line.
You might have better luck with CentOS. I am running CFX 18.1 in CentOS 7 and it works quite well.
-Maxim- is offline   Reply With Quote
Old   July 4, 2017, 10:08
Why support the most common linux distribution?
Old   July 5, 2017, 12:35
Ok. I installed centOS_1611 but cfxpre got the same error.
Old   July 6, 2017, 02:39
Maxim
You tried to open a different model or some tutorial files in PRE, right?! I hope it's not just a problem with your model...
As far as I remember, I didn't have any problems with Ansys 17 on CentOS either but I'm doing pre- and postprocessing in Windows...
I just openend PRE (18.1) in CentOS 7.3.1611 and it doesn't show an error.
Do you have access to Ansys 18.1?
I'm afraid I can't help you more here. I would recommend checking the Linux section of this board and contacting Ansys support.
Old   July 13, 2017, 10:07
Yeah i installed ansys 18 and it worked. But i need to use ansys 17 on cluster. Now i write my .def files on a slow windows machine with 17. But now i can go on...
Fu** ansys.
Thanks 4 reply.
ansys 17, cfx, gui, ubuntu
CEL expression in CFX pre Jane92 Main CFD Forum 1 June 3, 2016 02:48
Alignment Problem in CFX Pre st7rocks Main CFD Forum 0 February 27, 2016 12:39
Numerical oscillations in CFX with water boiling problem. michujo CFX 4 December 16, 2011 09:00
Urgent Problem with Hypermesh and CFX Luk CFX 5 March 14, 2008 04:59
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 04:07
