Home > Forums > Software User Forums > CONVERGE
No heat release in a simulation
Old   April 18, 2018, 07:29
Default No heat release in a simulation
liyong
luckyboy is on a distinguished road
I'm simulating a SI engine with hydrogen as fuel. However, the result showed hydrogen wasn't ignited. It's just like a compression stroke.
In my case, there isn't spark plug geometry(I don't know if this can be done). I set a point coordinate as a source location, and the others such as source energy(0.02J), max temperature(50000K) is same as example case.
so what caused the problem?
luckyboy is offline   Reply With Quote
Old   April 30, 2018, 14:46
Dan.Maciejewski's Avatar
Dan Maciejewski
Dan.Maciejewski is on a distinguished road
There are many things to look at in this case to understand why ignition is not being predicted:
If SAGE is used for combustion, is it with a mechanism developed for hydrogen fuel combustion?
Is the fuel / air ratio in the correct range, and is it at sufficient temperature and pressure to sustain combustion?
While the energy source, modeling the spark, provides the initial energy input to begin the combustion, other conditions must be the correct range to sustain combustion.
Dan Maciejewski
Senior Research Engineer, Applications
CONVERGECFD
Dan.Maciejewski is offline   Reply With Quote
can't ignited
Total heat release rate - variation not expected Bufacchi OpenFOAM Running, Solving & CFD 14 May 15, 2020 06:35
Heat release of diesel in dual fuel engine simulation PRJHA CONVERGE 1 March 30, 2017 11:42
Quenching simulation : how to set up a conjugate heat transfer between solid&liquid Rockda FLUENT 24 August 30, 2016 06:33
Question about heat transfer simulation Anna Tian Main CFD Forum 0 January 25, 2013 18:53
heat release? eric Siemens 1 February 27, 2006 17:53
